Harmony Adapter / Lässt sich nicht Instalieren.
Kann jemand den Harmony Adapter instalieren, bei mir schlägt dauernt die Instalation fail. Alle anderen Adapter lassen sich aber Instalieren.
Was sagt das log?
iobroker 2018-02-20 17:03:16.129 info exit 13 iobroker 2018-02-20 17:03:16.125 error host.iobroker Cannot install harmony iobroker 2018-02-20 17:03:16.125 info host.iobroker install adapter harmony iobroker 2018-02-20 17:03:16.124 info npm ERR! Please include the following file with any support request:npm ERR! /npm-debug.log iobroker 2018-02-20 17:03:16.123 info iobroker 2018-02-20 17:03:16.111 info npm ERR! Please check if you have git installed and in your PATH. iobroker 2018-02-20 17:03:16.111 info npm ERR! This is most likely not a problem with npm itself. iobroker 2018-02-20 17:03:16.111 info npm ERR! Failed using git. iobroker 2018-02-20 17:03:16.111 info npm ERR! iobroker 2018-02-20 17:03:16.111 info npm ERR! not found: git iobroker 2018-02-20 17:03:16.111 info npm ERR! code ENOGIT iobroker 2018-02-20 17:03:16.111 info npm ERR! npm v3.10.10 iobroker 2018-02-20 17:03:16.111 info "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.12.3 iobroker 2018-02-20 17:03:16.102 info npm ERR! Linux 4.13.4-1-pvenpm ERR! argv iobroker 2018-02-20 17:03:16.078 info npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923 iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' } iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5 iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5 iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16 iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29) iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19) iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12) iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b becau iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5 iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5 iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16 iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29) iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19) iobroker 2018-02-20 17:03:16.076 info npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12) iobroker 2018-02-20 17:03:16.076 info npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package npm WARN addRemoteGit Error: not found: git iobroker 2018-02-20 17:03:12.789 info npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call) iobroker 2018-02-20 17:03:12.744 info host.iobroker install adapter harmony iobroker 2018-02-20 17:03:12.735 info npm ERR! /npm-debug.log iobroker 2018-02-20 17:03:12.735 info npm ERR! Please include the following file with any support request: iobroker 2018-02-20 17:03:12.729 info npm ERR! Please check if you have git installed and in your PATH. iobroker 2018-02-20 17:03:12.729 info npm ERR! This is most likely not a problem with npm itself. iobroker 2018-02-20 17:03:12.729 info npm ERR! Failed using git. iobroker 2018-02-20 17:03:12.729 info npm ERR! iobroker 2018-02-20 17:03:12.729 info npm ERR! not found: git iobroker 2018-02-20 17:03:12.727 info npm ERR! code ENOGIT iobroker 2018-02-20 17:03:12.727 info npm ERR! npm v3.10.10 iobroker 2018-02-20 17:03:12.727 info "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.12.3 iobroker 2018-02-20 17:03:12.725 info npm ERR! Linux 4.13.4-1-pvenpm ERR! argv iobroker 2018-02-20 17:03:12.701 info npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923 iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' } iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5 iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5 iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16 iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29) iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19) iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12) iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b becau iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5 iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5 iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16 iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29) iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19) iobroker 2018-02-20 17:03:12.691 info npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12) iobroker 2018-02-20 17:03:12.686 info npm WARN deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package iobroker 2018-02-20 17:03:09.377 info npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call) iobroker 2018-02-20 17:03:09.332 info host.iobroker install adapter harmony iobroker 2018-02-20 17:03:09.317 info npm ERR! /npm-debug.log iobroker 2018-02-20 17:03:09.317 info npm ERR! Please include the following file with any support request: iobroker 2018-02-20 17:03:09.312 info npm ERR! Please check if you have git installed and in your PATH. iobroker 2018-02-20 17:03:09.312 info npm ERR! This is most likely not a problem with npm itself. iobroker 2018-02-20 17:03:09.312 info npm ERR! Failed using git. iobroker 2018-02-20 17:03:09.312 info npm ERR! not found: gitnpm ERR! iobroker 2018-02-20 17:03:09.310 info iobroker 2018-02-20 17:03:09.308 info npm ERR! npm v3.10.10npm ERR! code ENOGIT iobroker 2018-02-20 17:03:09.308 info npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "install" "iobroker.harmony" "--production" "--prefix" "/opt/iobroker"npm ERR! node v6.12.3 iobroker 2018-02-20 17:03:09.307 info npm ERR! Linux 4.13.4-1-pve iobroker 2018-02-20 17:03:09.287 info deprecated node-xmpp-stanza@1.1.0: use @xmpp/xml package iobroker 2018-02-20 17:03:09.286 info npm WARN iobroker 2018-02-20 17:03:09.273 info npm ERR! git clone --template=/root/.npm/_git-remotes/_templates --mirror https://github.com/swissmanu/ltx.git /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923 iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) code: 'ENOGIT' } iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5 iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5 iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16 iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29) iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19) iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12) iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit git+https://github.com/swissmanu/ltx.git#cdata-for-ltx-parser resetting remote /root/.npm/_git-remotes/git-https-github-com-swissmanu-ltx-git-cdata-for-ltx-parser-d923f26b becau iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at FSReqWrap.oncomplete (fs.js:123:15) iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/access.js:8:5 iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/node_modules/isexe/index.js:44:5 iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at /usr/lib/node_modules/npm/node_modules/which/which.js:90:16 iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at E (/usr/lib/node_modules/npm/node_modules/which/which.js:81:29) iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit at F (/usr/lib/node_modules/npm/node_modules/which/which.js:69:19) iobroker 2018-02-20 17:03:09.266 info npm WARN addRemoteGit Error: not found: gitnpm WARN addRemoteGit at getNotFoundError (/usr/lib/node_modules/npm/node_modules/which/which.js:14:12) iobroker 2018-02-20 17:03:05.658 info npm install iobroker.harmony --production --prefix "/opt/iobroker" (System call) iobroker 2018-02-20 17:03:05.344 info add harmony
geändert: Code in Code-Tags; Homoran (Mod)
Wie befürchtet:
@Cornadius:iobroker 2018-02-20 17:03:16.111 info npm ERR! Failed using git. iobroker 2018-02-20 17:03:16.111 info npm ERR! iobroker 2018-02-20 17:03:16.111 info npm ERR! not found: git iobroker 2018-02-20 17:03:16.111 info npm ERR! code ENOGIT ```` `
BItte git installieren:
sudo apt-get install git
Super danke, wahr eigendlich der überzeugung ich hätte es schon drauf. Danke für die schnelle Hilfe
Eine Frage hab ich aber noch zur Harmony, irgendwie muss ich wenn ich im Hub was ändere dauernt den Adapter deinstalieren weil er von alleine die Einstellungen nicht aktualisiert.
