  2. Русский
  3. ioBroker
  4. ioBroker драйвера
  5. Драйвер ioBroker Admin
89 Beiträge 18 Kommentatoren 37.0k Aufrufe 1 Beobachtet
  • E Offline
    electric69
    Обновление драйвера admin "зависает".
    Просто останавливается на моменте как на скриншоте и все…
    Содержание лог-файла:
    ! 2015-01-20 23:10:11.163 - ^[[32minfo^[[39m: host.bananapi Update repository "default" under "conf/sources-dist.json"
    ! 2015-01-20 23:10:26.907 - ^[[32minfo^[[39m: iobroker upgrade admin
    ! 2015-01-20 23:10:31.143 - ^[[32minfo^[[39m: iobroker npm install iobroker.admin –production [/opt/iobroker/lib]
    ! 2015-01-20 23:10:35.875 - ^[[32minfo^[[39m: iobroker npm
    ! 2015-01-20 23:10:35.886 - ^[[32minfo^[[39m: iobroker
    ! 2015-01-20 23:10:35.893 - ^[[32minfo^[[39m: iobroker WARN
    ! 2015-01-20 23:10:35.918 - ^[[32minfo^[[39m: iobroker package.json daemonize2@0.4.2 No repository field.
    ! 2015-01-20 23:11:50.537 - ^[[32minfo^[[39m: iobroker npm
    ! 2015-01-20 23:11:50.547 - ^[[32minfo^[[39m: iobroker
    ! 2015-01-20 23:11:50.562 - ^[[32minfo^[[39m: iobroker WARN deprecated object-keys@0.2.0: Please update to the latest object-keys
    ! 2015-01-20 23:14:51.002 - ^[[32minfo^[[39m: iobroker npm install "/opt/iobroker/node_modules/iobroker.admin" –production --prefix "/opt/iobroker/node_modules/iobroker.admin"
    ! 2015-01-20 23:15:28.140 - ^[[32minfo^[[39m: iobroker got /opt/iobroker/node_modules/iobroker.admin/admin
    ! 2015-01-20 23:15:28.164 - ^[[32minfo^[[39m: iobroker upload admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/index.html index.html text/html
    ! 2015-01-20 23:15:28.203 - ^[[32minfo^[[39m: host.bananapi object change system.adapter.admin.0
    ! 2015-01-20 23:15:28.222 - ^[[32minfo^[[39m: admin.0 terminating http server on port 8081
    ! 2015-01-20 23:15:28.208 - ^[[32minfo^[[39m: host.bananapi stopInstance system.adapter.admin.0
    ! 2015-01-20 23:15:28.299 - ^[[32minfo^[[39m: admin.0 terminating
    ! 2015-01-20 23:15:28.209 - ^[[32minfo^[[39m: host.bananapi stopInstance system.adapter.admin.0 killing pid 2256
    ! 2015-01-20 23:15:28.346 - ^[[32minfo^[[39m: iobroker upload admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    ! 2015-01-20 23:15:28.440 - ^[[32minfo^[[39m: host.bananapi instance system.adapter.admin.0 terminated with code 0 (OK)
    ! 2015-01-20 23:15:28.463 - ^[[32minfo^[[39m: iobroker Adapter "admin" updated
    ! 2015-01-20 23:15:28.693 - ^[[32minfo^[[39m: iobroker exit 0
    ! 2015-01-20 23:15:30.761 - ^[[32minfo^[[39m: host.bananapi instance system.adapter.admin.0 started with pid 5209[/spoiler]
    • BluefoxB Offline
      BluefoxB Offline
      Необходимо обновится до 0.4.5. Я нашёл коварную ошибку….. Которую сам же встроил. :(
      • I Offline
        I Offline
        instalator
        Сменил в настройках порт, админка не загружается по новому порту, где хранятся настройки чтобы вернуть порт обратно?
        Нашел, поменял, не помогло. Выставил в Bind 0.0.0.0 - в итоге завелось
        Высокий уровень Децибел вреден для здоровья!
        http://blog.instalator.ru/
        • BluefoxB Offline
          BluefoxB Offline
          @instalator:
          Нашел, поменял, не помогло. Выставил в Bind 0.0.0.0 - в итоге завелось Ну ты хоть EDIT или UPDATE пиши: > Сменил в настройках порт, админка не загружается по новому порту, где хранятся настройки чтобы вернуть порт обратно?
          UPD: Нашел, поменял, не помогло. Выставил в Bind 0.0.0.0 - в итоге завелось `
          А то получается как будто "тихо сам с собою я веду беседу :)
          • I Offline
            I Offline
            instalator
            Вроде как промелькивала версия 5.0. хотя сейчас показвает актуальную 4.8?
            • I Offline
              I Offline
              instalator
              Не первый раз наблюдаю подобную картину. Стоит обновить страничку и обновлений оказывается нету.
              • I Offline
                I Offline
                instalator
                Как переменные добавить раскидать по комнатам?
                • BluefoxB Offline
                  BluefoxB Offline
                  На данный момент это возможно, но очень и очень неудобно.
                  По моему кто-то пишет улучшение. http://forum.iobroker.net/viewtopic.php?f=24&t=894
                  • I Offline
                    I Offline
                    instalator
                    обновил до 0.5.1 страница не открывается, бесконечно крутится шестеренка. vis открывается
                    • I Offline
                      I Offline
                      instalator
                      Поставил npm install ioBroker.admin поставилась версия 0.4.8…Обновил снова до 0.5.1 опять не грузится админка.
                      • I Offline
                        I Offline
                        instalator
                        Как всегда сам с собой пообщался. Вообщем нужно сначала обновить сервер а потом админ.)
                        • E Offline
                          electric69
                          Может было уже, повторюсь, в адаптерах есть какой то "flot", иконки нет, в логе ошибки…
                          • I Offline
                            I Offline
                            instalator
                            @electric69:
                            Может было уже, повторюсь, в адаптерах есть какой то "flot", иконки нет, в логе ошибки… `
                            У меня нету. Хотя пробовал руками как то поставить. Это я так понял будет новый драйвер дня рисования графиков
                            • BluefoxB Offline
                              BluefoxB Offline
                              Спасибо. Ошибка в /opt/iobroker/iobroker-data/node_modules/ioBroker.js-controller/conf/sources-dist.json
                              Вместо (строка 27)
                                "flot": {
                                  "meta": "https://raw.githubusercontent.com/ruhr70/ioBroker.flot/master/io-package.json",
                                  "icon": "https://raw.githubusercontent.com/ruhr70/ioBroker.flot/master/admin/flot.png"
                              должно быть
                                "flot": {
                                  "meta": "https://raw.githubusercontent.com/ioBroker/ioBroker.flot/master/io-package.json",
                                  "icon": "https://raw.githubusercontent.com/ioBroker/ioBroker.flot/master/admin/flot.png"
                              Можно поменять ручками или дождатся следующей версии (не скоро)
                              • I Offline
                                I Offline
                                instalator
                                @Bluefox:
                                Вместо (строка 27)
                                  "flot": {
                                должно быть
                                  "flot": {
                                Можно поменять ручками или дождатся следующей версии (не скоро) `
                                Дак flot все таки работает уже? у меня его в списке вообще нету.
                                • aurodionovA Offline
                                  aurodionovA Offline
                                  aurodionov
                                  @instalator:
                                  Дак flot все таки работает уже? у меня его в списке вообще нету. `
                                  Ставится и даже можно открыть по ip:8082/flot/edit.html
                                  Пишу с пульта….
                                  • I Offline
                                    I Offline
                                    instalator
                                    @aurodionov:
                                    @instalator:
                                    Дак flot все таки работает уже? у меня его в списке вообще нету. Ставится и даже можно открыть по ip:8082/flot/edit.html
                                    Поставил…. Выбрал период 14 дней комп завис наглухо... пришлось ребутить жестко по кнопке.
                                      aurodionovA Offline
                                      aurodionov
                                      l
                                      Это по божески, я два месяца выбрал ,вот прикурил так прикурил. неттоп на атоме час почти в дауне был.
                                      Думаю со временем починят .
                                      Пишу с пульта….
                                      • I Offline
                                        I Offline
                                        instalator
                                        @aurodionov:
                                        l `
                                        Причем вешается не сервак а клиентская машина
                                          aurodionovA Offline
                                          aurodionov
                                          Не комп, браузер(пробовал ток под хромом), i7 не повесил, просто затупил
                                          Пишу с пульта….
