ioBroker Forum
Nutzungsbedingungen |Datenschutzrichtlinie
Cloud |Dokumentation
Aktuelle Zeit: 17.01.2018, 09:39
Alle Zeiten sind UTC+01:00
Ein neues Thema erstellen  Auf das Thema antworten  [ 15 Beiträge ]
Autor Nachricht
 Betreff des Beitrags: Timers, Events & Stuff
BeitragVerfasst: 23.10.2017, 19:50
Offline
starter
Danksagung erhalten: 2 Mal
I was wondering if anyone ever made a timer in ioBroker.
Like switch on a lamp but switch it off after 5 minutes.
But there is more ...
Every time an specific event happens (like a Motion detector is set off) it resets back to 5 minutes.
Could I use the JS controller for that and fire it off for every specific timer ?
_________________
[ HA : ioBroker/node-red ]
[ Devices : rflink/mi-light/rf433/mpd/kodi/mqtt/sonoff/nodemcu/broadlink/mysensors/rPI ]
[ OS : Running on Debian Linux ]
Nach oben
BeitragVerfasst: 23.10.2017, 19:59
Offline
guru
Benutzeravatar
Hat sich bedankt: 40 Mal
Danksagung erhalten: 212 Mal
IcaruS hat geschrieben:
Hi Icarus and welcome!,
Sure you can there are several options to archive you goal depending how much experience in scripting you have.
I guess for your scenario the most feasible way would be to use the JavaScript adapter.
Within that you can choose to create code yourself or the blockly way to do.
There are some examples in this forum unfortunately in German but if you need help give a shout and I/we can post an example by blockly.
When doing please ensure you also always reset timers, did you already have a look at our JavaScript documentation:
https://github.com/ioBroker/ioBroker.ja ... /README.md
Or the related blockly documentation:
https://github.com/ioBroker/ioBroker.ja ... ckly_en.md
Send from mobile device
Nach oben
 Betreff des Beitrags: Re: Timers, Events & Stuff
BeitragVerfasst: 23.10.2017, 20:12
Offline
starter
Dutchman hat geschrieben:
I do have some scripting experience... And can read and understand most stuff
I think I might go for the JS route
When I did a google search 2 posts popped up ...
Yeah I think I will go the JS route ... had some bad experiences with Blockly in Domoticz ... (shifting from domoticz to ioBroker at the moment)
Wish there was some more extensive docs with examples on the JS adapter ;-)
Thanks for replying Dutch...
(I'm back to tinkering with my HA at the moment again ... Had a few busy months at work... so work hard, but no play)
_________________
Nach oben
BeitragVerfasst: 23.10.2017, 20:23
Offline
guru
Benutzeravatar
So finally time to play ;-)
If you need assistance give a shout we are willing to help :-)
I can imagine searching a German forum could be a little hard for you.
Btw: may I ask which country is your origin?
Nach oben
BeitragVerfasst: 23.10.2017, 20:30
Offline
starter
You have to ask ?
LOL... look a bit back in the English Forum (Yep ... ben helaas Nederlands, Wij zijn de reden dat er een Nederlands gedeelte is opgezet :-P ...)
Was wondering how many Dutch people are using ioBroker
BTW: Isn't this a nice thing to put in a adaptor? (Adaptor has a few timers, which can be configured in the config, and if the script or settings publish a state ater the timer runs out ...)
_________________
Nach oben
BeitragVerfasst: 23.10.2017, 20:44
Offline
guru
Hat sich bedankt: 143 Mal
Danksagung erhalten: 266 Mal
fortunately there is an adapter for that: scenes
Choose a trigger, let's say your front door light's datapoint STATE. If it switches to true the scene is started. Within the scene configuration you can check more datapoints to be set to specific status, even with delays. Let's stay with the front door lamp.
In case you turn it on it will start the scene. The scene is set to turn it off after 300s (or 5min). Voilà!
The real benefit comes from the scalability to more datapoints. If you turn your lamp on (maybe triggered through a motion detector or you chose the datapoint of the motion detector itself) you can define more datapoints to be set. Turn on the stairway lights, play favorite music, set heating...
So, before diving into the deep waters of scripting try out scenes :D
Gruß,
Pix
_________________
Mac mini (OS X 10.12.6, node v6.12.2, npm v4.6.1), Redis, InfluxDB, VIS via iOS; gesteuerte Systeme: Homematic CCU2, Homepilot, Roomba, Sonos, XEOMA auf Odroid XU4; Adapter: feiertage, tvspielfilm, rtv, solarwetter, tankerkoenig, homepilot, epson_stylus_px830
Nach oben
BeitragVerfasst: 23.10.2017, 20:50
Offline
starter
pix hat geschrieben:
Gruß,
Pix
Lol... I should have looked closer at that then :P
_________________
Nach oben
BeitragVerfasst: 23.10.2017, 21:21
Offline
guru
Benutzeravatar
Lol sorry i forgot so welcome back!
@pix
Related to scenes, not that familiar with it yet, can you also cancel a timer there?
Use case: motion sensor states on and you turn on a lamp + define timer to set it off after x minutes.
If the "on" state is triggers again your want to cancel the current timer
Nach oben
BeitragVerfasst: 23.10.2017, 21:25
Offline
guru
that depends :lol:
If you are switching a Homematic Actuator you can also set its ON_TIME Datapoint and it will manage that issue for you.
To be honest: I haven't try out yet. :oops:
Pix
_________________
Nach oben
BeitragVerfasst: 23.10.2017, 21:47
Offline
guru
Benutzeravatar
that depends :lol:
Pix
Ok than I will have a closer look at scenes too.
Was just wondering as in regular scripting, blockly but also on a ccu you need to reset the timer itself and haven't seen that function in the scene adapter (yet)
Nach oben
BeitragVerfasst: 24.10.2017, 23:02
Offline
starter
Scenes is not exactly what I'm looking for as it is triggered every time it's set :(
Will see what I can do with a bit of scripting...
_________________
Nach oben
BeitragVerfasst: 25.10.2017, 06:14
Offline
guru
Benutzeravatar
If you are not used to handle things in JavaScript start with blockly, hit the button show code and see what script is created.
It will help you learning/understanding how it works with easy examples.
The trigger you are looking for in blockly will be the one were you can choose between updated (trigger at every value update even if it's the same) or changed (trigger only if value is changed)
~Dutch
Nach oben
BeitragVerfasst: 26.10.2017, 00:05
Offline
starter
Created a timer script which can be triggered and sets an expire time every time it gets triggered.
The script checks it's own time against the expiretime ... and acts accordingly ....
Tried 3 times to upload the script for others .. but the forum won't let me post it as code :(
So i'll try to upload the Scripts & JSON.
Maybe someone has a use for it ... or can make the code better :)
Dateianhänge:
Dateikommentar: JSON File
delaytimer.json.txt [2.11 KiB]
21-mal heruntergeladen
Dateikommentar: JS Script
delaytimer.js.txt [15.38 KiB]
26-mal heruntergeladen
_________________
Zuletzt geändert von IcaruS am 26.10.2017, 00:06, insgesamt 1-mal geändert.
Nach oben
BeitragVerfasst: 26.10.2017, 00:20
Offline
starter
Would be great if this would be an adapter with configurable timers :P
Several named timer which you could add to you scripts (That are reset every time it gets an update)
Great for motion sensors :)
_________________
Nach oben
BeitragVerfasst: 26.10.2017, 22:15
Offline
guru
Benutzeravatar
Mja it depends...
Not sure if a separate adapter is the way to go as you can also quite easily archive the same goal with JavaScript (expert) or blockly (advanced)
Could your also post a screenshot of your created blockly.
(Easier to read on mobile device :-))
Nach oben
Beiträge der letzten Zeit anzeigen:  Sortiere nach
Wer ist online?
Mitglieder in diesem Forum: 0 Mitglieder und 1 Gast
Du darfst keine neuen Themen in diesem Forum erstellen.
Du darfst keine Antworten zu Themen in diesem Forum erstellen.
Du darfst deine Beiträge in diesem Forum nicht ändern.
Du darfst deine Beiträge in diesem Forum nicht löschen.
Du darfst keine Dateianhänge in diesem Forum erstellen.
Suche nach:
Gehe zu Forum:
Powered by phpBB® Forum Software © phpBB Limited
Deutsche Übersetzung durch phpBB.de
